Veritas R8 Alarm triggers at different times
2 Sep 2024
Malta
I recently had a problem with my Alarm after someone mistakenly turn off the supply power it.
Long story short (and I'm not sure how I got here), I downloaded the installer manual and today I have the following situation:
The alarm has been programming PROG 33 to give a 90 second delay. This was up from the default 30 seconds.
* If I enter from the Garage (Zone 1) I get the full 90 seconds before the alarm triggers.
* I I come in from the front door (Zone 3) the alarm trigger instantaneously.
I tried reprogramming it using both the main unit as well as from the slave unit. Both seem to give the response described in the installer manual (my model does not have an LCD display) .
Is there some other setting I need to change to set all zones so that when I open either door I get the 90 second buffer?
Sounds like your zones are not programmed correctly.
At default zone 1 is e/e this gives you the entry delay before ala goes off.
Zone 3 default is intruder so going in via this zone triggers the alarm immediately
Thanks @secureiam
I found the entry.
Verify the zone you want to change:
set the alarm with the zone open (dorr in may case). The LED will light up.
Engineer code
PROG
1 + <zone you want to change>
6 <-------- Change it to entry exit
PROG
<unit chimes>
RESET
