Hi
Recently i had to replace both the panel and the bell. The bell fist because the strobe had stopped working. When i replaced the bell, i then found the strobe output was locked on from the panel - disconnected outputs and had a permanent neg applied at the panel. The busted strobe masked this issue. Maybe that is why it stopped working, as the strobe just burnt out wit it being on all the time and o-one noticing?
So I replaced both about three weeks ago. In the last week, the AG6 has sounded, and the type of fault the LED and sound the bell is making relates to loss of 12v supply.
Meanwhile the panel does not register this, it remains in an normal set condition - no tamper. I went back and did a few tests, and the only time this scenario could occur (bell 12v Fail butno impact to the panel), is if you drop the +12v hold off only (not negative) to the bell.
I swapped conductors over and checked termination and measured voltage at the bell and the panel. 13pluss volts at both ends, no wavering.
Popped iota back together then like i say, about a week later the same issue occurred. I have ordered a new non AG6 bell to rule it out.
Anyone come across this before?
Anything i can do differently?
If it does it again, after the bell has been replaced, i will replace for a galaxy.
John
John
