Vertical larch cladding join
13 Nov 2006
Kent
Hiya,
I am installing vertical larch cladding, I am at the area of the building where I need to start joining the boards.
I am not sure what the best practise is for this joint, I have scrolled the Internet and can't find any info.
I am thinking joining using a 40 degree cut to both faces so the boards over lap, leaving a clean seamless joint, then nailing the overlap, or do I leave gap for expansion being larch is so unstable.
Really not sure, any help guidance would ease my over active mind please.
The advice from the suppliers is just butt up tight.
You could use end grain sealer, which would be my recommendation.
personally I wouldn’t do an angled cut
timber does not expand in its length so that’s not an issue.
Thank you very much notch7, yes end grain sealer has been supplied.
After I asked I thought the same, timber doesn't generally expand in its length.
Thanks for your help.
