Hi All,
I have another can of worms query.
I was all set for getting a vertical radiator, probably like most until I saw the price... B & Q and Screw fix do something like I was looking for :
B & Q (web link was huge so left it out )
Vertirad Vertical Panel Radiator Anthracite Grey (H)1800 x (W)595 x (D)66mm
£197.00
Screw Fix
Same size oceanus rad (single)
£200
http://www.screwfix.com/app/sfd/cat/Designer_Radiators_OceanusRads.jsp?ts=52215
Duplex rads are £300 plus
Both these rads would fit the limited space I have as its a small vertical wall, however so will this:
It's a normal double rad that is 700mm wide and kicks out more heat and is £46!
http://www.screwfix.com/prods/22967...um-Double-Radiator-500-x-700mm-1070W-3652Btu#
I was wanting a bit of a feature and realise this is purely cosmetic but was wanting something a bit different.
Mounting a normal rad on its side would probably be a bit naff and my dad suggested mounting two radiators one above another (he was around woodstosck time) for a feature.
Any other ideas or experiences or recommendations or shall I just get my hand in my pocket?!..
£197.00
Screw Fix
£200
