I need to fit a vertical panel radiator in my kitchen because there's no room for a standard horizontal one. It will fit behind a door so there's a maximum thickness to consider (85mm), also the very max height is 1800mm because I don't want it to be visible above the door.
The maximum dimensions are:
1800mm high (preferably 1600mm)
650mm wide
85mm from wall to front face.
My heat output requirement is around 4400btus (1300w).
I've looked at Myson and Stelrad and neither seem to do one that is slim enough or not too tall. I don't want to pay the earth, it just needs to be a plain looking, standard radiator. All I can find is £300+ ones.
Does anyone have any ideas as to where I should look ?
Thanks,
Phil
650mm wide
Thanks,
Phil
