Vertical radiator recommendations
19 Feb 2015
Many vertical radiators appear to have a less than favourable reputation in terms of their actual output in relation to their stated output.
Would anyone care to suggest any specific brand(s) of vertical radiator (any style) for which the actual output matched expectations of stated output?
Thanks.
Are you talking about a vertical tube or column rad?
They will never heat the room as effectively as a convection radiator will unless they are seriously oversized. They heat the space differently.
Convection rads work 90% convection, 10% radiation, as such are the most effective at space heating. Their design actively encourages convection and channels cold air up up through the bottom through the finned space and exit hot out the top.
Column/tube rads work the opposite way, more like 80% radiation, 20% convection. They do create some convection, especially if they have more than one row of columns but not to any great degree as the air isn't 'channelled' as such and rely more on radiation.
This is the primary reason why column radiators of old were so large, they were seriously oversized to enable them to heat large spaces effectively.
I have had to change column radiators that have been installed back over to convection rads numerous times, especially in the older Glasgow tenements. They have large bay windowed 3.5m ceilings and the new 'designer' rads couldn't heat the space properly, some customers wont listen though.
The only time it ever really worked was a flat in the West End that had a large 5mx6m living room with a panelled domed ceiling 4m at it's peak, beautiful space but it took 8 x 700mm by 1400mm 10 column rads to heat it, even then it had a LDFE gas fire to augment the heat in winter and it certainly needed it.
They do look lovely but are really quite crap at heating larger spaces.
Potentially either, if it had good heat output.
I have one 1800 x 470 mm 3-column radiator in a 9 sqm room, and it takes 4-5 hours to get the temperature up to 20/21 C.
I had thought this was over-sized when I bought it, but even if it was double the size again it would potentially still take 2-2.5 hours.
Yup, sorry but I really do advise against them, in my experience they're rubbish at space heating. I only recommend them to augment the look of a room and not to be used as a significant part of any room heating.
The softline verticals are excellent radiators, they work on the same principal of convection over radiation so heat the room much faster.
Oh ... and they're not ally, they're mild steel as far as I know.
Nope ... they're both $hite .... ;)
Noted.
Is the mild steel a better material for radiator production than aluminium?
I wouldn't say it's necessarily a better material.
Steel heats up slower but retains its heat for longer. Ally heats up faster but cools down quicker. Steel does rust but proper inhibitor sorts that and aluminium will still corrode. Ally is lighter so easier to handle but I've never found that to be an issue.
Ally, I believe, is also easier to form into lots of different designer shapes for the up and coming and wannabe trendies out there :whistle:
Several have recently been removed from a no expense spared barn conversion and replaced with normal radiators. Completely messes up the "very trendy" architect's exotic design for the luxurious home but the owners wanted to be warm.
