Vertical Radiator suggestion
19 Feb 2015
I require a vertical radiator which which can fit into a space which is 25cm wide.
Therefore potentially the radiator could be up to 25 cm wide provided the outlets go vertically down from the underside and not out to the side.
It would have to be between 1.8m and 2.2m (max) in height for the correct output.
I was wondering if anyone had any suggestions?
There is the Tilbrook, though apparently these are out of stock by the main UK supplier until the end of next month:
http://www.heatandplumb.com/acatalog/ultraheat-ts1508w-tilbrook-vertical-radiator.html
(Unless anyone happens to know anyone who has one in stock).
My experience with vertical rads is that they can be quite top heavy so you really do need a good fixing to the wall. There are some available with feet which sit on the floor which helps spread the weight.
