Very draughty back door
5 Sep 2007
Newcastle upon Tyne
I have a wooden back door which is near my bathroom. The draught that comes through it is unbearable and makes that part of the flat freezing.
Not only does it come through the bottom of the door but also the sides.
Any solututions? There is a strip draught excluder running along the bottom but does not seem to be doing anything.
nicola
or save yourself a thousand pounds, carefully look at the existing draught excluder to decide why it doesn't work, and replace or renew it.
If you have drafts then the door is not fitted correctly, refit and then look at external draught excluder for a few pounds.
You can get a really good draught excluder that you screw into the outside of the door frame. It consists of aluminium lengths with a rubber seal - 3 lengths (top and 2 sides) - fitted it to our front door and it made a massive difference
Can't remember what its called though - I'm sure of the other guys on here can give you a product name ...
