Hi all
My speedometer needle behaves very erratically on most journeys for a few minutes and then returns to normal, I suspect the Vehicle speed sensor may be at fault but where is this located ?
Also I tried to check the actual cable from the rear of the gauge but was unable to access the perspex cover screws due to not being able to disconnect the Nissan anti theft system security light (red) cable, once I had removed the upper steering wheel casing.
Hope this makes sense, any info would be truly appreciated.
Semi-acoustic.
Semi-acoustic.
