I've recently had a wall done by the 'dot and dab' method. I then had a vertical radiator delivered which I was going to put on that wall BUT the radiator weighs 70kg (unfilled). There are just four small brackets. Can anyone tell me if the plasterboard (12mm) will take this weight? Or will I have to cut through it to get some more solid fixings on the brickwork behind it? Thanks.
