Hi all.
I have just moved into a terraced house and have an issue with low water pressure.
Water suppliers have checked the supply pipe/stopcock and its fine/fully open.
At all taps the water pressure is extremely low (doesn't even register on water authorities flow/pressure meter)
Literally takes a minute to fill a litre jug.
Is there anyway this can be improved?
The system is standard (old style) boiler/cold tank/hot cylinder. I'm no plumber but it seems to me that the entire house cold water is being fed from a gravity water tank, nothing is mains fed bar the storage tank. Is this OK/acceptable? The washing machine also does not work, flashes up a "low feed pressure error code"
Any replies are appreciated because in my opinion this is unacceptable.
