Hi
I have a workshop/shed in my garden which is around 20ft by 12ft. Its a pitched roof on the long side.
Felt is knackered, leaks a lot
Shiplap has a few gaps
Original door is leaking and rotting the floor
Windows are the normal pane of glass
Strengthen the roof
What I want to do (as cheap as possible but need it to last) is to make it water tight maybe put on a decent door and windows. Fix the floor and insulate.
1. Maybe put some OSB over the existing roof
2. Use EPDM on the roof (seems to be the cheapest/best solution)
3. Put in some decent joists to carry the roof
4. Put down some 18mm or 22mm chipboard flooring over what is there (fix the rotten bits first)
5. Put some insulation in the walls and ceiling (not too sure of what or how thick)
6. Put a membrane on the inside of the shed - as. I understand it, the insulation needs to be on the inside of this so might have to move these steps around
7. Buy a couple of window sets and a door and fit them
Does this sound about right?
Strengthen the roof
