veturi shower
10 Dec 2006
Kent
Hi,has anybody out there got any experience of venturi mixer showers,ie the trevi boost.As i have not got a cold water feed from my tank and this would be a right pain to run through the house.Do i install the trevi or bite the bullet and pull up my floors.Your thoughts would be appreciated.
Hi
i have fitted two trevi boosts recently they work great . You have to get a 22mm hot supply to shower which has to be the first tee from the cylinder this could be difficult in some houses but if you can go for it
regards paul
Fitted three (or is it four). They're marvellous.
When you're faced with an impossibly low head on the hot service, then yes they are.
