i have a vailliant turbo max vuw 242e that is driving me insane,
it will fire up give me hot water for about 20 seconds then every thing goes off , eny help would be appreceated
cheers stevff
Should the demand light be going out to, drop the control panel down the diverter valve is on the right. Can you see the small white plastic paddle on the right side of the diverter? It operates a green microswtich. If this paddle is not making positive contact then the boiler thinks there is no demand. A sympton of a torn diaphram/clogged mechanism.
If the temperature guage is getting too high, then see other posts about clogged heat exchanger.
