Vibrating humming glowworm 18hxi
4 Nov 2006
Oxfordshire
Hi there, our house backs onto a pub car park and for ages now we thought some guy came along in a souped up car, sat with the car idling then switched it off. Later on he leaves and goes home. Must be a massive car we thought cos it makes the house reverberate (sp?)
Turns out its our Glowworm 18hxi, fitted last november.
Assuming that is not meant to happen, what do you gentlfolk think it might be, is it likely to be harmful, and what should I do about it?
Tom
Has it been set up correctly i.e. with FGA?
iF not correct co2 reading then noise can result.
Does it stop when u use a tap or toilet?
Im not a plumber but i had a simmilar problem with a boiler vibrating, which sounded like someone was drilling next door, it was amazingly loud! turns out there was grit in the toilet mechanism causeing tapslam/water hammer cant remember what the plumber said in the end. Hope it gets fixed ok.
gasgeezer said:
Still under warranty call glowworm
Watch out on this one as usually Glow Worm 2nd year warranty is parts only and they ask for £125 up front before booking the call :rolleyes:
