VIBRATING LIGHT SWITCH
R
RBUNTING
LAST YEAR I REPLACED A WHITE SOCKET FOR A BRASS SOCKET WITH BLACK SWITCH. IT HAS STARTED TO VIBRATE WHEN YOU TOUCH THE BRASS, WHAT COULD BE WRONG WITH IT? :confused:
ONLY ASKING FOR ADVICE ON ELECTRICAL ISSUES NOT SARCASM!
_________________-
moderator
please note 6
capitals are used to indicate shouting and words to be read in a bad temper, so be carefulwhen you use them.
If you have, or can borrow, a meter with an AC volts range , you can measure to see if there is any voltage betwen the exposed metalwork, and sometihng you know to be earthed - waterpipes, or perhaps a long lead back to the consumer unit earth.
more than perhaps 2 or 3 volts, and there is a problem.
Come back and let us know what you measure.
