Hi all.
Sorry for a repeat of a question posted many times before .
My house is 60 years old. The loft cold water tank sits on a purpose built, by the builders,
Platform. It's been ere since new.
I've changed the float valve several times in the past, they are always have a thick encrusted lime scale covering. I just fit a new valve.
Recently the present valve started oscillating whilst filling. Plastic tank,no strengthening plate.
I checked the water surface, not easy task, and there was the tell tale surface waves.
I could stop the vibration by holding the input 15mm pipe.
I fitted new valve, oh god, same result. Not easy for a 6'4 bloke in my loft.
The pipework is unsupported. I'm going to have to build some framework so I can fit pipe clips.
Temp fix, I've wedged some poly styrene between pipe and tank shelf.
Because this problem only just started I'm wondering if thetank support frame work may have moved? Hence stressing the tank
