I would welcome any suggestions for the following problem.
I have recently replaced some radiators and fitted Drayton TRV4 valves. All ground floor rads are on inverted loops i.e.the pipes run around at 1st. floor level and drop down to each downstairs rad. The system is 10mm microbore. On three of the downstairs rads,the TRVs vibrate when the temperature reaches shut off point. They do not vibrate when fully open.
It is definately the TRV,because a small turn of the knob stops the noise. The jumper must be trying to close, but is receiving back pressure to prevent it doing so. The valves, which are supposed to be bi-directional,are on the return side.
I have tried everything I have read on this site. e.g. bleeding the system with the pump off; shutting down the lockshields to just half a turn open; reducing pump speed to its lowest setting. The rads still warm up, but the valves vibrate, sending shock waves into the system.
It is an open -vented system with 13 rads.The problem is only on 3 downstairs rads. Any thoughts from the experts,please.
