Victorian Radiator
23 Mar 2007
We just received an old victorian radiator last week. For the past week my fiance has been trying to strip and and started wondering if there might be a leak anywhere. We have to pay someone to bring it in the house next week, and then pay a plumber to set it up. We were wondering if there were anyway to test the radiator outside. Also if there are any leaks is there a way to fix them? Like if it's from a crack in the body or something? Thanks
Jen :?:
Can you put up a pic?
The ones we have over here are made of iron sections. There is a threaded rod running inside the top and the bottom to hold them together.
I've never done it but I believe it is possible to undo the nuts and take each section off, then you can re-make the joints with a new sealing compound and fasten the sections back together.
I should think it would be easier to get the paint off when they're apart too.
