Hi Ree - thanks for showing and interest!!!
Have been trying to read as much as I can about the possible solutions but there are lots of conflicting opinions varying between open ventilation and sealing everywhere is vapour barrier.
Concerned that this house will always have damp under floor boards which airbricks alone wont keep below acceptable levels - dont want to do a load of work on a wooden floor only for it to go rotten in a few years. Looks like the current floor was replace only around 10 years ago although the builder didnt use any DPC over sleeper walls, bridged the woodwork and external walls with lots of dirt and debris and also managed to block the airbricks....
Concerned that adding a membrane and more robust oversite would stop the damp directly in the floor but may force more damp up the walls? Also concerned that this additional weight may also contribute to subsidence???
Concrete joists rather than wood seems a logical approach - again would welcome any views and advice on insulation/ventilation
A modern solid floor with integral insulation layer may be another option but guess this removes any ventilation from the walls (issue or not?). Also concerned about services entering property which would be above an oversite and below floors, similar for internal electrics and central heating - little reluctant to bury pipework - guess the electrics could be chased above the floor
Ultimate aim is to add extension in the side return and a loft conversion so if any option provides better structural support for this it will have advantages. Similarly, floor considerations for side return. guess taking the floor level right down would reduce the damp issue in to lounge but how to stop it at the edge of new extension? french drains?
Some of the internal walls are built directly onto the floorboards without direct support from sleeper walls. Was considering putting strong foundations under these and building up structural support as this looks like an area of potential failure in future so would want to sort this while the floor is up - any advice?
Thanks for any help
1) photo of outside showing foundation depth, ground level and level of airbricks
2) showing yard in side return, all cracked and pipes from kitchen/bathroom into drains
3) space under floorboards, some parts of sleeper wall removed and wall plates removed (as not stable and rotten), shows depth of current floor space under joists. cant really see but airbrick entry is just below plaster level, airbricks outside are above the skirting board level (removed)
4) view under floorboards, very damp, debris from previous builder (chimney breast removal) still there, lots of earth
5) view under floorboards, lots of damp debris, the white stuff in later photo
6) white gunk, looks dry and crystaline in photo but is very wet creamy paste when touched -WHAT IS THIS???? doesnt smell of anything...was expecting it to smell mouldy but doesnt
7) photo (sideways) of fireplace hearth. note damp patch in surface (doesnt dry out) not sure if coming from below or from wall where chimney removed and possibly letting rain in from roof....??
