We've just moved in to a Victorian property. I've noticed that some of the walls are pitted rather than smooth and those that aren't seem to have a thin wallpaper underneath the paint.
Is this paper a common way of covering up pitted plaster? Would I be best to paint over it again or should i peel off the existing paper and put new paper one/have the walls skimmed (some of it is peeling at the corners)? Is it likely to take half the wall off if I do peel it off?
For skimming, roughly how much would I be paying someone ph in London?
Thanks.
Thanks.
