I have a Viega Multiplex Trio bath filler/overflow/waste that I am trying to fit but it only has one water inlet. I therefore need to somehow take the water from my bath side valves (not yet fitted) and mix it before it enters the trio unit.
If I do this though will the back pressure of cold water be too much for my combi boiler? (glowworm flexicom 30cx)
The only way I could think of mixing the two (hot/cold) would be to fit a t piece prior to the trio unit - is this correct, or should I be looking at pressure reducing valves or even binning the whole idea and going for normal taps etc.
I do not want the bath to take too long to fill either, so I may have to just rething?
Any views please before the steel bath gets drilled today for filler valves?
