Hi There
We have the above system installed after some building work was completed. Before the work was done our Viesmann operated faultlessly, but now the boiler has been moved from the house to the garage, we have issues.
1) Firstly, the builder trashed the compensator sensor - replaced
2) We couldn't get warm enough - Viesmann suggested we get a vitotrol300 fitted internally - now done.
3) still cold.
The are no faults lit, and the house is cold. Internal temperature demand is set at 23, outside temperature (according to the control panel) is at 12, and the same panel reads an internal temperature of 17 - no matter what we try we can't get it to go any higher.
Reading around, it seems that the compensation curve needs changing, but after spending an hour googling, i find lots of advice telling me this, but the actual magic to change this remains a mystery.
Can anyone give me any advice? If not, I am just going to put the jumper in the compensator sensor and knock it out of the circuit - this lack of heat is making me grumpy.
Thanks in advance
Mark
3) still cold.
Thanks in advance
Mark
