PRV changed when F1 fault started. Supposedly fixed air blockage to fix the F2 but it came back again over the weekend. Came back out yesterday and supposedly cleared more air blockage. Left and F2 reappeared. I've reset system this morning but turned it off when temp showing 110 degrees and kettling. Any suggestions?
Is that boiler a system boiler with a internal circulation pump or a heat only boiler with a external pump? and is it a sealed system or a a gravity system with a small feed and expansion cistern in the attic?.
