Early this morning we returned from Holiday to find the boiler in Low Pressure alarm and Water all over the worktop - the boiler is a Viessmann Vitodens 100 30kw installed into the house from new in 2006.
My first reaction was to top up the system using the top up loop to see if the water would come straight back out and to increase the pressure. As I filled it up the low pressure warning disappeared and the boiler attempted to fire up - I increased the pressure to about 1.4bar. After a few minutes of the pump running the Fault F5 appeared which apparently means the burner is blocked and the air pressure switch is faulty.
After reading the book it appears there is a PRV that might have discharged the water, but my query is whether the the release of pressure would have caused the F5 fault and fixing this fault code would still leave the high pressure problem or whether the blocked burner would have caused the high pressure that activated the PRV.
Please let me know what you think and whether my ideas are well off track? Either way I am going to need to find a Veissmann familiar engineer ASAP as it a combi boiler and we have a 7 month old baby to care for.
Cheers
Cheers
