System worked fine before, in fact it’s only 18 months old and was just serviced. But I just took off a radiator to redecorate and after putting it back on and filling it up I have at F2 fault.
When turning the hot water on, the temperature goes up past 100 and then the F2 appears. So it appears it’s overheating.
-I have tried resetting
-I have tried bleeding the boiler and repressurising
-Radiators all appear full and properly bleed
-Pressure is 1-1.2ish
-Central heating works fine
Any clues? Do I need to get a gas man out?
