- Joined
- 14 Jan 2016
- Messages
- 3
- Reaction score
- 0
- Country
I have a 4 year old Viessmann Vitodens 100 Combi boiler feeding an unvented hot water system and underfloor heating system.
My issue is with the hot water circuit.
When the hot water system switches on in the morning and the boiler fires up there is distinct rattle/judder which lasts a second or so and seems to come from somewhere between the boiler outflow and the motorised zone valve (Honeywell 4043 2-port). This occurs again with the first significant use of hot water (shower/bath) but will not occur again until the next on cycle (mid afternoon).
The piping is secure at the boiler end and cylinder end, although I guess there could be a loose clip somewhere in the pipe run.
Any thoughts? I was wondering if there might be some sort of pressure issue or perhaps a sticking valve resulting in a sudden surge of water in the circuit. Or could the coil inside the hot water cylinder be loose (Santon Premier Plus)?
I am not a plumber!
I am not a plumber!
