Hello all!
I've just got a new Combi boiler installed and would like to clarify two things (I have heating off atm and DHW set to 50ºC (which is default).
- While using hot tap water, display shows it goes to around 64ºC. Shouldn't it be around 50 as per setting?
- In DHW, does it matter if water goes above 54 (or whatnot) in order to render condensate heat inutilised? Or does condensation heat-usage only applies to heating?
Regards and thank you!
