do you actually have to provide a view from a window in a loft conversion or can it be high up for light only?
this is not for any kind of practical application, just a 3d house I'm drawing for fun..
there's a roof purlin at 1.5m from the floor, supported on the 2 end walls, and 3 intemediary walls along it's length ( it's a big house.. 18m wide.. ) so I'd rather not cut that if I can help it. ( again, all virtual, no actual house will be harmed.. )
the roof currently allows for a 4.6m wide space along it's entire length with a ceiling height of 2.4m..
if I expand outwards then I get into the sloped roof area.
I suppose I could lower the purlin and put a second one in at a higher position, allowing the windows to be put at a reasonable level and make the rooms wider into the sloped areas..
