This ' overhead cammie doodah bit' was a two stroke - actually
[code:1]
ID Part
Number Description Quantity
- Engine arrangement for Villiers 2T Engines 0
1 E8260 Chaincase filler cap 1
2 C10035 Pipe inlet 1
3 E401 Nut standard hexagon 11
4 E2924 Washer Plain 22
5 E10104/1 Washer insulating inlet pipe stud 4
6 - Cover carburetter and air filter group 1
7 E9974 Washer joint inlet pipe 1
8 D9973 Washer joint cylinder base 2
9 E4011 Stud fixing inlet pipe 4
10 A10102 Cylinder left hand (Mk. 2T) 1
or D11781 Cylinder left hand (Mk. 3T) 1
11 B9291/1 Cylinder Head left hand 1
12 E9983 Nut cylinder and head studs 8
13 E3985 Washer cylinder and head studs 8
14 B9292/1 Cylinder head right hand 1
15 C9899 Washer joint cylinder head (Mk. 2T) 2
or E10953 Washer joint cylinder head (MK 3T) 1
16 A10103 Cylinder right hand (Mk. 2T) 1
or D11782 Cylindcr righthand (Mk. 3T) 1
17 C9733 Plate joint cylinder (Mk. 2T) 1
or E10904 Plate joint cylinder (Mk. 3T) 1
18 E5578 Washer exhaust pipe nut 2
19 E8564 Nut exhaust pipe 2
20 B9984 Stud fixing cylinder and head 8
21 EG.532 Trunnion pinch bolt 1
22 E9618 Bolt pinch lefthand crankcase 1
23 E1050 Washer 4
24 E3961 Nut 1
25 M2800E Clip cable 1
26 E2539 Nut small hexagon 12
27 E8183 Stud fixing crankcase 4
28 E8015 Dowel armaturc plate 1
29 D8928 Washer joint armature plate 1
30 - Magneto asssembly 1
31 A10179 Cover right hand (less contact brcaker cover and ignition switch) 1
32 E7916 Screw righthand cover 2
33 E8670 Screw contact breaker cover and left hand name plate 6
34 B10180 Cover contact breaker 1
35 A8371 Crankcase right hand (Mk. 2T) 1
or D11440 Crankcase righthand (Mk. 3T) 1
36 E1905 Washer drain and level screws 3
37 E1962 Screw drain 2
38 E8250 Dowel crankcase right hand cover 2
39 E7129 Screw righthand cover and chaincase 2
40 E8440 Stud long gearbox end cover 2
41 V107x3E Washer gearbox drainplug 1
42 E6292/1 Plug drain gearbox 1
43 E5107 Stud short gearbox end cover 2
44 D8066 Cover end gearbox bushed 1
45 E783 Bolt gearbox end cover 2
46 D8929 Washer joint gearbox end cover 1
47 E4900 Adjuster clutch cable 1
48 C10246 Gearbox shell bushed (Mk. 27) 1
or C11821 Gearbox shell bushed (Mk. 3T) 1
49 E2152 Stud gearbox/crankcase 4
50 C8927 Washer joint gearbox/crankcase 1
51 E8199 Stud aligning crankcase 2
52 E6593 Washer dipstick 1
53 E10287 Bush mounting lug crankcase 4
and E10458 Bush mounting lug gearbox 2
54 E8193/1 Dipstick gearbox 1
55 E8456 Screw carburetter cover 1
56 A8370 Crankcase left hand (Mk. 2T) 1
or D10902 Crankcase lefthand (Mk. 3T) 1
57 E10420 Seal oil chaincsse 1
58 D9057 Washer joint crankcase/chaincase 1
59 E5146 Stud fixing chaincase rear half 3
60 E1430 Washer spring 1/4" 3
61 A8060/1 Chaincase rear half 1
62 E8275 Screw oil-level chaincase 1
63 C8196 Washer joint cbaincase 1
64 E8185 Screw fixing 2
65 A8061 Chaincase front half 1
66 FC153E Screw fixing chaincase/gearbox 1
67 C8482 Cover nameplate left hand 1
68 E7326 Screw short chaincase front half 4
69 E2667 Washer screw 1
70 E8261 Washer filler cap 1
71 E7619 Dowel gearbox 4
[/code:1]
yesss !!
