Hi
I recently bought 2 sets of old christmas lights, (probably 1950s). They were working when bought (ebay). They do not have plugs on and have 2 wires, not 3. How can I put a plug on? Many thanks.
Well, given that the seller obviously had them working, I would double-check with them that they are definitely for use with mains electricity. If they are, then the intention is for one of the wires to go to live in your plug, one to neutral BUT given their age, I would take great heed of their warning about having a safety check done.
for the £5 you paid for them i would just use them as decorations, no plug EVER.
If they are as old as claimed they will be breaking down through age, on the other hand they may be only a few years old, personally i would not take the chance
My recipe for using old Christmas lights is to rewire them in parallel and power them from a suitably rated transformer (something like 12V, 20VA). The transformer has to be chosen carefully otherwise your bulbs will go up in smoke. The transformer will probably cost you £10-15 as well!
then to rewire them in paralell, hmmmmmm lot of time involved not to mention lots of nice connections to break down, sorry, stick to using them as non iluminating decorations
Hi
Many thanks for your thoughts. I think I'll get a safety check done after checking with the seller. They would look good as decorations but it would be great if they worked as lights, I'll post again to let you know the outcome. Thanks again.
