is there is a pattern on the floor were you could take an offcut if for
example its a square patern you take your offcut with the relivant square
on it you tape it firmly on top of the dammaged bit you then cut
[in the grout lines] through both layers and providing you cut with
the blade verticle the bit you cut out will be the same as the extra bit
