Vinyl flooring in en-suite
30 Jul 2020
I’m having an en-suite fitted and looking to use vinyl sheet flooring. The room is completely empty at the moment and I will have the floor put down before anything is installed as I do not want cuts around the toilet, vanity unit etc. I am having a corner quadrant shower fitted - can the flooring go slightly under the tray to avoid a cut or will this make the tray uneven?
Also, the tray is a Mira flight safe quadrant try and is a very slim profile. It advises you can use silicone to fix it to the floor - has anyone done this and is happy this is long lasting/firm enough?
Many Thanks in advance
Cut the flooring around the tray a silicone the joint
I bedded a mira flight tray on silicone and its its been fine for the two years since fitting
