- Joined
- 7 Jan 2010
- Messages
- 13,476
- Reaction score
- 3,368
- Country
Are the white cables that Virgin media use indoors just the same as co axial aerial cables?
Yeah you can use it for ariels, done it loads of times, had a mate who worked for virgin gave me a few drums.I had Virgin boxes in some rooms, but got rid. The cable seems to have RF connectors, so wondered if they could be used with the aerial I have so I have points for tv's in other rooms.
The question isn't whether HD100 can be used for aerials. It can because it should be a better spec than a lot of the standard RG6 rubbish sold for aerial and satellite hookup.Yeah you can use it for ariels, done it loads of times, had a mate who worked for virgin gave me a few drums.
Edit, the outdoor black stuff I used but I assume it's the same
Is it? In post #3 he says he has the virgin cables already installed and could he use them for ariel pointsThe question isn't whether HD100 can be used for aerials. It can because it should be a better spec than a lot of the standard RG6 rubbish sold for aerial and satellite hookup.
The question is the other way around. Can stuff sold for TV aerial use also be used for Virgin Media.
This is a different proposition to you and your mate's drum of VM cable.
If you've even seen some of the junk sold under the 'RG6' banner then you'd think twice about using it for aerials let alone VM. It's garbage. Steel core (copper anodised to look genuine, but still easily magnetised and it rusts in the presence of atmospheric moisture), barely-there aluminium(!!) braid shield with a Mylar plastic foil. Loose outer jacket. Electrically more lossy than good coax. Rarely any spec either. It's just bad.
Using aluminium for part of the shielding function is risky. If there's any moisture, like through a crack in the brittle outer jacket, then the ali will corrode and turn to mush.
The shielding does three main jobs. First, it provides a signal return a bit like the negative connection on a car battery. Without it, no signal flows.
Second, it 'catches' the energy from interference much in the same way as a TV aerial picks up radio waves. Foil covers the higher frequencies up into the satellite (GHz) range. Braid covers the lower frequencies down to baseband video.
The third function is to provide a conductor to ground for this trapped energy. Metal foil is already bad for this, but Mylar (plastic) is the pits. This is why the metal braid is needed.
If the braid starts to bemreakdown at some point the it will go high resistance. This causes signal loss, but it's really hard to pinpoint the cause since this is under the sheath and so out of sight.
None if this is an issue with a copper cable. I've been to houses where the end of the copper aerial cable at the TV has been dripping water but there was still some TV signal.
Paying good money for bad cable is very short-term thinking.
Ah, my mistake and my apologies. I missed that he'd replied between yours and mine.Is it? In post #3 he says he has the virgin cables already installed and could he use them for ariel points
Interesting. I have a reel of probably several yards of that in the loft. The bloke who installed our router all those years ago left it (intentionally).If they're what VM used to install, then te answer is no. They have extra shielding. Three layers rather than two for coax now used for TV and satellite.
Thank you. I'll send for one of them.VM use compression connectors. For a one-off job you'll do fine with one of the kits from eBay. See eBay item no. #285531131138.
I'm looking forward to it... I think! Not until well after Christmas anyway.Be aware fitting compression f connectors is not foolproof. DAMHIKT!
