Virgin Media second phone socket from master
8 Mar 2010
London
Hello all,
I am trying to add a second phone point from my Virgin Media master socket.
On the back of the master socket it has be numbers 1-6, but there are only 4 connectors. Thinking they would be in fact 2 -5 I wired up the second one as such. However it doesn't work at all.
I used wire from an extension kit as I Wickes had that in stock but not "naked" cable without plugs at each end. I assume that wire would be ok?
I have tried two different wires to see if that was the problem but it wasn't. I have managed to wire eight Ethernet ports today, using a proper Krone tool so an confused as to why the phone doesn't work.
I have put some photos here.
//www.diynot.com/network/IanWood/albums/11552
Is there something else I need to do?
Could the master socket itself to broken?
Any help would be most appreciated.
Cheers
Ian
do you have a multimeter?
is the wire stranded or solid?
does the phone socket on the front of the master socket work?
I do own one but can't find, yet...
standed
Yes, that fine.
I am looking for the multimeter, does the type of wire make a difference then?
Cheers
Thanks for your tip.
Found my multimeter.
I think the problem is that the wires haven't been cut by the connectors. When I try the multimeter from connector to connector I get nothing. When I stick the pointy bit into the end of the cables I do get a reading.
Is the cable getting squashed rather than cut due it being stranded? Sounds like I should use different cable. Would a long enough Ethernet cable to suitable?
Cheers
Ian
Cheers
Ian
Correct single core telephone cable and ( a Krone tool for correct cable insertion - not the plastic throw away version )
Thanks Plugwash - it was your hint about stranded wires and using multimeter which solved the problem.
As I was running out of time I bought another network starter kit from B&Q for £30...
Used Ethernet cable and a proper tool. Phone works now. Overspec for phone use but couldn't afford to waste any more time.
Best bit - I don't even use the landline, she does!
Cheers
Ian
