can anybody tell me how to remove vista(urghhh) from a laptop so as i can load xp on
Do you have the XP cd? yes
Have you tried entering bios and changing to boot from disc rather than hard drive? Normally to get into bios its F2 or F10 or ESC/F2, it will normally say during start up. tryed that as well
Make sure you've saved everything you want to save on there to a separate drive or external one.
When you tried to format the drive were you logged in as administrator?
I know they hide the logon in vista and its a pain to find think this explains how.....on page 2.
http://www.computerworld.com/s/arti...e_true_Administrator_account_in_Windows_Vista
In this you hopefully should be able to reformat, which you wont be able to do in just a user account.
Gobo said:Also when you tried booting from disc you just prioritized cd boot and didnt take the hard drive out of the sequence?
All very well pointing out what I said but you've done nothing to answer the question.
Your XP CD doesn't have the required drivers for your system. If it's not an SP2 or SP3 CD, try and get one, it is then you will need to integrate them to the CD.
What make and model is this laptop?
Gobo said:All I meant monkeh was he could do with a bit more explanation.
Is it possible to write the xp disc onto usb and then update it? Then boot from that?
