Yes.Vokera Compact HE and Honeywell cmt927
Is this a job a DIY novice can do?
Forgot about that. It will have to be disabled.There is a time dial on the boiler but nothing external to that.
That's no problem.Im at work at the moment but when i do have a go at this would you be ok if i pm'ed you?
It might be a good idea to carry out the tests before fixing the receiver to the wall! Honeywell say a minimum of 30cm from any metal objects, including the boiler. The easiest way to do this is temporarily to connect a long lead with a 3 pin plug at the other end to the L and N terminals. Plug into a 3 pin socket, hold the receiver where you want it located. Then check reception from the proposed transmitter (user control) location. Once you have found a receiver location that works reliably, you can then fix it to the wall and run the four core cable to the boiler.carry out transmitter/receiver tests as per cmt 927 instructions
Yes.So are the black wires interchangeable (as in can either go in A and either in B)
B&Q sell it Tower 4 core cableAlso any chance of you linking me to the correct 4 core cable i need to buy from maplins or screwfix?
Any two core cable will do the trick. Just put a plug on one end and connect the other end to the L and N terminals of the receiver.Also D_Hailsham what kind of cable will do the job you described in your last post?
Does this mean the wires that were connected to my internal clock will be brown,blue and 2 blacks.you will have wires connected to a brown, a blue, and 2 blacks
Does this mean i will have totally removed 4 complete wires from the boiler as they were connected to the clock and the connector block?disconnect wires from the 4 colours stated
And to complete i run the purchased 4 core cable fro m my reciever box to the now empty connectors on the connector block of my boiler.from vokera connector block to cmt 927 receiver
blue to n(eutral)
brown to l(ive)
black to A
black to B
Yes.Does this mean the wires that were connected to my internal clock will be brown,blue and 2 blacks.you will have wires connected to a brown, a blue, and 2 blacks
Does this mean i will have totally removed 4 complete wires from the boiler as they were connected to the clock and the connector block?[/quote]disconnect wires from the 4 colours stated
Correct.And to complete i run the purchased 4 core cable fro m my reciever box to the now empty connectors on the connector block of my boiler.
