Vitodens 100 boiler, low pressure, can't find the valves
24 Mar 2013
Bath
Hello, the boiler in my house is not working and the reset light keeps flashing. I have read someone else's posts, it looks like I have to refill the pressure by open the valve, but I cannot find any valve. Can anyone tell me which one is the valve?
Picture on left, the two chrome valves with the braided flexible between them, on lower right of picture. That's your filling loop. Use a screwdriver to turn the slotted screws so the slot is inline with the valves. Turn them back to where they are now to stop filling. Don't overfill, 1 bar is enough.
The layout of your photos in this thread has changed since I last looked, now they're all on the left. Best way to describe the image I'm referring to is your first picture (of the pipe-work underneath the boiler) ;)
Then Liuliu when you have done that and solved the problem, return here to say its ok and to thank everyone.
You can also used the "thanks" button.
Only then is the job completed!
Tony
