I've searched for anything like this problem, both on the web in general and here at DIYnot in particular, without anything near it.
I noticed when I woke up this morning, that I could here the whisper of the central heating . When I checked the Honeywell controller it was still set to manual (which is how I use it) and 18 degrees (which equals off above that temperature) and the ambient was 21.5 but the heating was still on.
I’ve tried everything in descending order from fitting new batteries to the controller, turning down the temperature on the heating side of the boiler, switching the controller to off, until I have now turned the boiler heating control to the off position but the heating still comes on!!!
Although our boiler man has a call-centre answering system, as this isn’t in the same league as the previous problems – water leaking from the boiler pipework (the last problem), the boiler shutting down in the cold snap last winter (condensate pipe frozen, which we controlled with pouring boiling water over it), heat exchanger passing and, of course, our old friend the sticking flap valve, I’ll leave him to his Sunday and call him tomorrow.
Unless, of course anyone out there has an answer – if not, I’ll post the outcome here for all to see (and find).
When I was looking for a new boiler in 2006 this one came out tops and I have been having the “you said this was the Rolls-Royce of boilers” thrown at me by “The Management” ever since . All-in-all I think I made the right choice then and would seriously think of having another one if we moved.
Another hour or two of searching and the predicted Rolls-Royce of boilers dig when she got in from relly visiting and I've found a hijacked post here //www.diynot.com/forums/viewtopic.php?t=234831&start=0 on DIYnot which suggests a diverter valve problem?
Would that mean the heating side would only get fed while the water side was in use?
