It may sound like a basic question, I have a newly fitted Vitodens 100-W, 35kW Combi.
When I turn the hot tap on the boiler is triggered a couple of seconds later and hot water is flowing. The pressure drops slightly, which I guess is the boiler compensating for heating the water timely in order to form a steady flow. So I have to open the tap a little more till I get stable flow of hot water at mains pressure. This is most likely a standard function of combi.
The problem is there is a minimum flow required for the boiler to "activate" hot water. And this is not a small flow, it's a lot of water which I find a waste when for example I need a small flow to wash tools or brush my teeth in the bathroom, or shave. If the flow is less the boiler will stop heating and cold water start coming out.
Is there any setting to the flow sensitivity for this function or is this hard coded into the boiler by the manufacturer? Just curious.
