Could you help me fix a simple but nightmarish problem? I replaced a Dual Flush toilet syphon universal valve, VIVA. Everything was good until the local water company told me I was losing water. I had a very fine trickle from the tank into the bowl. So, ensuring the water in the tank wasn't overfilling and trickling down the overflow tube on the flush valve and buying a VIVA Skylo diaphragm washer and replacing it, I still have the same water trickle problem. I would like to know what holds the diaphragm washer over the flush valve and prevents it from leaking through. Is it the weight of the water in the tank, or does the mechanism have sufficient weight to hold it firm over the flush valve? I can't see any other cause for the trickle except someone out there might know why I have the problem.
