vivaro 05 smoke/lack of power
16 May 2008
Norfolk
:confused: help bloody van driving me mental
maf sensor fault flagged on tech 2-fit new ok for a while-same fault back tis forced me down new ecu path-same again-now no faults flagged no warning lights just runs rough/black smokes/lack of power-also fitted new egr valve(clogged and seperated when removed)
:confused: help b****y van driving me mental
I would assume the van is a diesel? black smoke is an indication of too much fuel, or put another way incorrect fuel air mix.
First thing to check is the air filter, does it require changing?
is the van turbo charged? if so, possible blocked intercooler, or turbo fault.
Wotan
Overfuelling on a diesel would cause white smoke (unburnt fuel)
Black smoke is usually excessive oil being burnt, or choked are filter
I would say that the white is an indication of serious amount of unburnt fuel but black is an indication of just a little too much fuel which is not being burnt and as stated usually a blocked/restricted air intake.
Tony
Black smoke is overfuelling.
Blue smoke is burning oil.
White smoke is steam.
