Vivaro cuts out, engine management and stop light on
4 Feb 2011
Birmingham
Hi all
I was wondering if someone could help me out, my vivaro 52 plate 2003 was left standing for about 3 weeks, then it would not start, i got it taken in and was told the high pressure pump had gone, had that changed, filter replaced, fuel lines and tank all cleaned through and cam belt done. the van now starts but when going up to 3000 revs it dies, if you turn the ignition off and then on it will start and run again, the engine mangement light is on so is the stop lamp. i have had a look at it with opcom and i am getting error code P0191 low fuel pressure, another mechanic has told me to change the fuel pressure switch on the common rail, would this solve the problem?
I have also done two read outs if this helps someone tell me whats wrong.
this one at idle
Accelerator Position Sensor Signal,0 %
Intake Air Temperature,5 °C
Mass Air Flow Sensor,49 kg/h
Boost Pressure,100 kPa
Coolant Temperature,53 °C
Vehicle Speed,0 km/h
Brake Switch 1,Inactive
Clutch Switch,Inactive
Desired Engine Idle Speed,865 RPM
Engine Speed,872 RPM
Cam/Crank Sensor Signal Synchronisation Status,Synchronous
Fuel Pump Relay,Inactive
Common Rail Fuel Pressure,36.438 kPa
Fuel Temperature,13 °C
Boost Pressure Command,85 %
EGR Position Command (Exhaust- Gas Recirculation),34 %
EGR Position Feedback (Exhaust Gas Recirculation),0.00 V
Glow Time Relay,Inactive
Diagnosis Glow Time Relay,Active
Heater Relay 1 (Additional Electrical),Active
Heater Relay 2 (Additional Electrical),Inactive
Heater Relay 3 (Additional Electrical),Active
A/C Information Switch (Air Conditioning),Inactive
A/C Pressure (Air Conditioning),0 kPa
A/C Relay (Air Conditioning),Inactive
Output 1 Cooling Fan Relay,Inactive
Output 2 Cooling Fan Relay,Inactive
Engine Telltale (Check Light),Off
Glow Time Telltale,Off 12V
High Coolant Temperature Lamp,Off
Desired Idle Injection Quantity,14.8 mg/strk
Injection Quantity,15.0 mg/strk
Barometric Pressure,100 kPa
Instantaneous Consumption,2.8 L/hour
Idle Speed Offset,40 RPM
and this one at 2000RPM
Accelerator Position Sensor Signal,19 %
Intake Air Temperature,6 °C
Mass Air Flow Sensor,94 kg/h
Boost Pressure,104 kPa
Coolant Temperature,57 °C
Engine Speed,2.106 RPM
Common Rail Fuel Pressure,50.353 kPa
Fuel Temperature,16 °C
EGR Position Command (Exhaust- Gas Recirculation),37 %
Desired Idle Injection Quantity,0.0 mg/strk
Injection Quantity,11.6 mg/strk
Instantaneous Consumption,6.0 L/hour
Thanks in advance
Pressure is to low.
1. Not getting fuel from the tank = pipe blocked or something in the bottom
of tank
2. Faulty pressure sensor on the rail and the engine management can't
"see" the correct pressure in the fuel rail.
Thanks for the reply.
The tank and all fuel pipes have been taken off and cleaned so I dont think it is a blockage, another mechanic has also mentioned the sensor on the rail so I have called around and so far it looks like a dealer only part and vauxhall want £296 for the sensor :eek:
I have found a place that can do me one cheaper but I need the bosch part number but i can not see it on the sensor
