All,
While investigating a couple of small holes that had appeared on the edge of my drive, I discovered a large void which appears to run underneath the ring foundation of my garage block. The area I was looking at is to the LHS of the garage where the car port is. We are out in the fens so ground conditions are not ideal for building so I am slightly concerned the garage is going to start disappearing into a big hole in the ground! The garage is supposed to be on piled foundations born out by my discovery of one of the piles (See photo below..)
The garage:
The area of the drive showing where I stuck the spade in initially. The spade met very little resistance... The two holes looked a bit like rabbit holes but could have been caused by water I guess. There are some cracks.in the clay surface under the gravel..
I thought I should have a look a bit further back so stuck the shovel into some cracks in the soil close to the garage and the spade basically disappeared. The soil seems to have a consistency of sand which I am guessing is imported topsoil as we are out in the fens and the rest of the garden is very peaty. A couple of minutes of digging produced this:
Sticking a camera and light down yielded:
Here is a video clip looking underneath:
https://photos.app.goo.gl/nqNwCfDEtdDzs6Dy7
The video clip was taken from the end of the trench nearest the fence. The void appears to run as far as my torch would illuminate across the back of the garage and obviously the whole way forward to the front of the garage. The void is about 2 feet across and the inner wall seems to be peaty soil. Judging my the cobwebs and so on the void has been there some time.. There is no sign of movement anywhere in the garage structure so I guess the piles and ring are doing their job.
My questions are:
1) Do I need to do something about the void?
2) Assuming I need to get somebody to investigate further, what speciality should I be talking to?
2) What is the likely cause of the void?
Thanks!!
Jonathan
[footnote]Edited by brycheiniog1 on Sunday 30th September 20:56[/footnote]
The garage:
My questions are:
Thanks!!
Jonathan
