Vokera Linea 28. approx 9 y/o installation in a new build.
My problem is that I have hot water but no heating.
I have been installing two bathrooms in a flat. In one bathroom the existing rad was replaced with a 'designer' rad, and in the other the existing rad was removed, and the pipes capped. The system was sitting drained down for about 3 weeks.
New bathrooms installed, floors tiled. Job done - or so I thought. Having refilled the heating system a few days before, I was happy that pressure was sitting at 1.5bar. Stuck the heating on to test, but no heat to any of the rads. So I drained & refilled the system. Still no joy.
Pump motor is spinning & bled, and I can hear the divertor valve motor is operating.
Occasionally, after a reset, the boiler fires up the c/h but cuts out after the stat reaches 65c. The flow & return pipes leading directly to & from the heatexchanger get hot, but there is no heat at the RETURN isolating valve, and some heat at the FLOW isolating valve and a few inches down the pipe for a few seconds, but as soon as the burner cuts out it goes cold immediatley.
Any ideas? I'd be pulling my hair out if I had any.
Need to get the C/H working, and get off the job. Thanks in advance for your help lads.
