Vokera 12/48 r.s.e. Mynute problem
31 Jan 2007
Hi. I posted yesterday but didnt have all info available.
Vokera 12/48 RSE Mynute Boiler. Runs fine till thermostat kisk in. Then wont start. Fan keeps running untill it is manually reset. I now suspect buildup in the heat exchanger. Anyone any Ideas?
Also, wher's the best place to but parts?
DP thanks for your help so far.
Thermostat on the boiler or on the wall.
If on the wall, I would be looking for 3 core earth cable for mains dial type stat.
If boiler stat is the culprit, it might be better to meter the circuit and see why the sequence is arrested.
