So as not to confuse this with my previous post i will add it as a new topic.
Vokera 24, after heat exchanger replacement the boiler will not operate for long when the CH is asked for (10-15 seconds) , DHW OK.
Problem seems to be that there is not enough flow through the heat exchanger which shuts the boiler down through an over temp fault. When i crack the thermistor on the exchanger there is just steam coming out, to me this backs up the lack of flow through the exchanger theory. I have removed the pump and switched the boiler on briefly , the pump spins and cannot be stopped by exerting pressure on the impeller.
So the question - what am i missing as this is driving me crazy, i even refitted the old exchanger but the problem still exists
Regards -- Kenny
Regards -- Kenny
