- Joined
- 14 Aug 2023
- Messages
- 2
- Reaction score
- 0
- Country
I have a vokera vision 25s that has had its pcb recently fitted due to a fault with the pcb , with the new pcb it works however it seems to be always on , the display is flashing the number of the temperature its currently at even when the programmer is not sending any singal to turn on the water/heating the boiler still seems to be on just not fired. Is this a pre heat feature and if so how do you turn it off ? As when you put up the temperature on the boiler it fires up until it reaches the temperature but does not turn fully off , there is nothing in the manual that says about a pre heat feature that I can spot any help would be great
