Hi people
I have a Vokera Compact HE that is under a years warranty with Vokera through Domestic and General.
I had the Expansion vessel replaced a couple of weeks ago followed by the pipe that leads to the expansion vessel as apparently this was full of muck/debris.
Since then I haven't been able to fill a full bath with hot water as it keeps going cold (no error lights apparent on boiler).
I rang the insurers to explain this and they sent out an engineer again via Vokera who without really testing or inspecting it much said its due to the plate heat exchanger being clogged up.
Now Vokera have said this is nothing to do with the expansion vessel and tube repair and is user error as the water is not clean enough and therefore they're insurers wont cover the repair?
Does this sound right?
Is it just a coincidence to have happened straight after having repair work done?
Are the parts totally seperate and how can I be at fault if its a closed system?
Domestic and General were quite helpful and said if I were to organise an independant plumber who said it was something other than the plate heat exchanger then they would still cover the repair but from previous experience the plumbers around my area don't want to touch Vokera for some reason?
Can I ask the people here for advice on this matter please?
Kind regards
Kind regards
