Got a vokera 20-80 flowmatic boiler. The pressure reflief valve was leaking even when down at 1 bar, so replaced that. Then pressure shot up straight away, so recharged expansion vessel. Difficult to do with the valve where it is but on 3rd attempt, seemed to have got it. But pressure rose to 2 bar from 1.5 bar, so called corgi guy out. However, in the 1- 1.5 hrs it took for him to get here the pressure maintained its level (when switched off). Guy took filling loop out and reduced pressure to 1 bar (nothing was coming out of the filler loop valve so that was ruled out.). When boiler fired up the pressure rose to 1.5 bar but guy said that was normal so possibility that i over pressurized system. Bloke gave instructions: advised that i should run with heating on with hot water off and check pressure in a couple of hours, if pressure rose then new expansion vessel needed. Alas when checked pressure was at same 1.5 bar level.
Following instructions, i then switched on hot water valve, used water and then checked after couple of hours and the pressure was back up to 3 bar and discharging from relief valve. Bloke reckons it might be heating exchanger.
Called him and he advised to reduce pressure back to 1 bar keep water valve open but not use hot water, then go and check in morning. If pressure ok then reckons it will be thermostat, but bloke reckons this is an outside chance.
Just wondering if anyone had any thoughts on this?
